i was putting in my new suspension in my 93 accord and i went and got the ds front strut out and when i got it out the cv axle joint came apart inside the boot and now it wont bend back in far enough to put it all back together. How can i realign it?
cv axle.
You are talking about the inner plunge joint right? it has three square slides that slide in a track sort of. if you pull it out to far it will come out of the track and it will go right back in unless you have got one of the square slides twisted. If you can feel it through the boot you might be able to feel the track and the square pieces and make them line up and put them back in. If you do have to take it apart clean the boot and joint first dirt is bad in there. i just reused the boot and zip tied where the clamp used to be. is hasnt come off yet and its been a year or so now.
I had both of mine come apart when I did my clutch. I lightly tapped one back in. The other one... I destroyed it.
Whacked it on the ground until it was all messed up. Never got it back in. So I exchanged it as a core on a new Autozone reman. I haven't gotten the car on the road yet to see if the one that went back together is still ok.
If you pull the joint completely apart and don't mark which bearing set goes inside which channel then when you put it back together again it won't work so well.
make sure to mark the bearing three tripots before pulling them out of the outer race (if you do end up doing to to realign them and get them back in) so you can put the tripot assembly back in the same grooves they came out of.
Also if you are gonna pull them fully out you need to wrap around them with masking tape or something so the roller bearings don't fall off the threetripot "axles".
