should i, or is anyone else getting one of these HONDA PILOT/RIDGELINE/S2000/ACCORD/PRELUDE PRO TUNER there on ebay http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
progressive pro tuners for accord?
I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
Oja Thnx Everyone, at cb7tuner.comTags: None
seems like a pretty good deal
Originally posted by Oja View Postshould i, or is anyone else getting one of these HONDA PILOT/RIDGELINE/S2000/ACCORD/PRELUDE PRO TUNER there on ebay http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessoriesI want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
All it does is intercept the signal from the IAT sensor, making the ECU think that the engine is taking in cooler air than it really is. At least from what I can gather. You'll be adjusting the fuel without actually adjusting the airflow.
I agree, it's cheap... and it might do something... but I wouldn't mess with a gimmicky thing like that.
Well..
Originally posted by deevergote View PostAll it does is intercept the signal from the IAT sensor, making the ECU think that the engine is taking in cooler air than it really is. At least from what I can gather. You'll be adjusting the fuel without actually adjusting the airflow.
I agree, it's cheap... and it might do something... but I wouldn't mess with a gimmicky thing like that.I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
Yes, but with this thing, you're not actually changing the oxygen content of the air you're taking in... just making the ECU THINK that you did.
It's oxygen that makes power in the engine. Fuel is basically there to act as a catalyst for ignition, and then to keep the burn controlled.
This thing is at least more believable than the "power chips" you see on ebay, but I'm not so sure that it would work any better.
whats funny is these things are usually tested on turbo vehicles because on a turbo vehicle with the IAC temp cooler the ecu will generally lean out the mixture and may run a bit more boost which is where they get that 22hp from. On a NA honda gains would be so minimal it would be a waste of money. You would probably gain more HP from a heatshield gasket and it would be better than trying to trick an ECU.
member ride thread
DIVULGE MOTORSPORTS
