Check engine light problem...I replaced my oxygen sensor, and checked my vacuum lines, plugged in air box reader thingy, and i still am getting the c.e.l.i disconneted the battery and reconnected it to reset it but a few miles later it popped back on.it turns on only after i drive it for few miles.whataya tink??i'm lost... i took it to autozone for them to pull the codes but the dipshit didnt want to mess with a 90(that bastard)...and i have to go thru emmisions next month so i just kniow it's gonna fail with that light on..PLZHLP A pissed CB7ener
Check Engine Light Driving Me Crazy
This topic is closed.
Just take it to another parts store to read it. Just remember they usually will NOT clear it but if they do, when ever they scan it (if they scan it, they will/should if the light is on) for emissions they will see the cleared code so remember that.
"The Turtle"
DD/Trail Rig/Mud Bug
http://www.cb7tuner.com/vbb/showthread.php?t=21259
Don't change parts unless you got the code.
Don't go through the hassle of people pulling the codes for you.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Originally posted by Konigstiger View Posthttp://www.cb7tuner.com/vbb/showthread.php?t=21259
Don't go through the hassle of people pulling the codes for you.SwaggerJacker
anyone who doesnt have 2mins to pull codes using nothing but a paper clip probably shouldnt be working on their car to begin with.
think i might start selling my junkyard sourced "code reader" to the noobs.
at the rate i am seeing "how do i pull codes" threads i could make a mint....
Originally posted by cvc7chris View Postauto parts stores only read cars with 96 up it wasn't his fault, which would be obd2, our cars are obd1, so you should learn to read and search and diagnose your own damn cel light.SwaggerJacker
"The Turtle"
Originally posted by H22artman View Postanyone who doesnt have 2mins to pull codes using nothing but a paper clip probably shouldnt be working on their car to begin with.
at the rate i am seeing "how do i pull codes" threads i could make a mint....SwaggerJacker
Originally posted by project_x View Postnot everyone walks around with a paper clip in thier pocket..
you can keep it on your key chain
Originally posted by 93F22A6 View PostYes you do. The egr is the exhaust gas recurlation sys. It basically takes exhaust gases and runs them back into the engine. It is located on the lft side of the intake close to the valve cover. It disc shaped and roughly 3 inches tall. Also has a vac line running into and if I'm not mistaken wires as well. Could be clogged to where it won't open or just a bad vavle, or something else.SwaggerJacker
