guys..
my car overheated few weeks earlier due to the rubber stopper underneath the dizzy bursts..luckily the head gasket was ok..now,what happen is that, the gauge reads normal while cruising,at the traffic jams and so on, but when climbing uphill, the temp rises up pass the mid level close to H and when i release the gas,it went down..i did inspect the water level inside the radiator and the resevoir and they're good.both fans are working but one of it is running slower than the other..could this be the cause my engine temp rises??
thanx in advance..
thanx in advance..
Hey you need to check that slow fan, it sould not work slow that may be your problem.
