why does my harmonic balancer sit and wobble around, did it suddenly break? what part of it possibly broke? is this difficult to change? thanks guys.
harmonic balancer?
if its wobbling to the point that you can visibly see it you should definately replace it. The unit consists of three pieces, 1 hub which is the part which the bolt secures it to the crank, Then there is a rubber ring then the outter accessory drive pulley portion of it. What most likely happened is the rubber on yours has deteriorated and has begun to loose its contact with the outter portion of the pully.
member ride thread
DIVULGE MOTORSPORTS
Originally posted by 93tunerofdacb7 View Postfunny thing is it didnt start doing it until i tightened my alternator belt.Originally posted by mozzandherb View PostI dont know if one has to do with another, but my harmonic balancer also started to wobble and needed changing. This happened shortly after I changed my alternator belt.
that, or the rubber on your crank pulley was on its way out already...
just replace it. should be fine after that.....
Originally posted by H22artman View Postsounds like you guys over-tightened the shit out of those belts.
that, or the rubber on your crank pulley was on its way out already...Last edited by johnl; 09-30-2009, 06:02 PM.Regards from Oz,
John.
