Going to JY.. To Get Harmonic Balancer
    Ok so tomarrow im going to the JY in hopes of finding a decent harmonic balancer.. my questions are what years will work for the cb ( i figure the newer the better condition.)
    I also want to know if anyone has a specific method and HAND tool list ill need to remove this thing.. i have a feeling its gonna be a pita.
    THANKS.
    ** BUY MY STUFF **
    A crankshaft pulley tool(if you got one), a couple 1/2in breaker bars(the longer the better), 19mm socket and a long pipe. That's all you really need to take one off. I'm not sure what other accord pulleys will work other than the cb ones. And yes, it's gonna be a pita
    [IMG]http://i166.photobucket.com/albums/u105/akona21/cb2-2.jpg[/IMG
      youll have to find a way to stop the crank from turning, normally thats done safely with a Crank Pulley Holder Tool but in your case (JY) might as well just throw something into one of the cylinders until it locks up the engine and it stop turning, then you can get the bolt removed.
        You might find an engine that's rusted shut. Probably wouldn't trust that the balancer tho, lol.
        -1992 CB7 EX w/H22 [sold 10/09]
        -2005 Legacy GT limited [current]
          Use a prybar or big flat tip to lock the flywheel, vise grips work too. Use a very good quality 1/2 drive and 6ptX
            rope down the spark plug port is gonna be the easiest way to do this without a crank pulley tool or an impact gun.
            go get yourself a small bundle of 1/4" nylon rope.
            remove a plug from whatever car you find with the best pulley.
            stuff some rope down the plug port.
            take your socket with extension(s) long enough to clear the fender and put it on the crank bolt thru the hole in the plastic cover.
            put a big ass cheater bar on your ratchet/breaker bar and proceed to remove bolt as normal.
            not that big of a PITA....
              WOW thanks for all the replies guys i def miss driving the cb and its only been a day.
              ** BUY MY STUFF **
                the jy's around here usually have a few cb7's in them. find one that has a 5 speed with the tranny still in (sometimes hard to find) shove it in 1st gear and get a buddie to lock the brakes down. push the brake pedal thru the floor if u have to but its the way i got the one off i needed.
                the rebuild!
                http://www.cb7tuner.com/vbb/showthre...50#post2073450
