will the p12 run the f22a1 with a6 im or should i get the h23 im. any suggestions.
accord ecu
The p12 does not have the ability to control the IAB system. Get the PT6 if you want to do that correctly. The H23 intake manifold makes no difference, as it also has an IAB system. You can run it by vacuum instead of the ECU, but that's not the way it was intended to work.
The P12 adds power to the stock F22A1. It doesn't necessarily add power to the F22A6, or a motor with the H23 manifold.
