I notice this when i actually drove this CB that i bought a couple days ago. The bottom right side of the cluster where it tells you what doors are open. Well thats flashes when ever im driving it does every min or so. Has anybody encountered this wierd problem? Everything in the cluster works perfect as well as the door signals. Its just when im driving that it does that! Any help will be grateful!
Flashing Doors Symbols
Originally posted by DejectedAngel View PostSure do bro. All 4doors including the trunk. It just flashes every min or more.?
maybe something in the key switch as well since all the lights light up when you turn the car on...
dont know. thats a strange one...
Oh noo dude. The cluster works great and everything. Its just when im driving the Door Symbols flash but thats it nothing else lights up.Originally posted by H22artman View Postin that case i'd guess towards a bad connection in the cluster.
Originally posted by DejectedAngel View PostWell its not that the doors lights are on. When im driving the cluster door lights come on. When all the door are closed dude. So i dont know whats going on.
what we are trying to tell you is to check the connection at the cluster.
its almost impossible that all the doors and the trunk switches would all be bad at once much less flash at the same time UNLESS you have a bad connection at the cluster. especially if your courtesy lights and dome light are off when the doors are closed.
remove the cluster and inspect the pins for that area of the cluster for corrosion or rust damage.
you have a bad connection/ground somewhere.
better break out a wiring diagram....
Oh ok bro. I taught that yall pictured that all my lights on the cluster would light up. But ok man im taking off the dash bezel in a min or soo and i will let yall know what happend. Thanks for your help dude.Originally posted by H22artman View Postdude.
Thanks aswell bro!Originally posted by GT-101 View PostSince all the lights are flashing it seems like an issue with the wiring on the cluster. If it was only one of the door lights that was turning on I would say look at the connection on that door, sometime those spots rust and cause a bad ground.
Originally posted by H22Artman View Postin that case i'd guess towards a bad connection in the cluster.
dont know. thats a strange one...90 LX 5spd 2dr (2011-2014)
93 EX 5spd 2dr (2013-2015)
92 LX 5spd 2dr (2015-present)
Originally posted by KW3gLuderInaCB7 View PostIm having this problem as well... all lights flashing while driving and its happening more frequently... your idea with it being something to do with the key switch makes sense... since i got the car the key in beeper goes off anytime i have either door open... even when they keys arent in. any ideas on what i should do next to diagnose the problem? im fairly good with electical.
