yesterday i did the balance belt delete. redid timing<-- im sure its off by give or take 2... but today i started it up and it started fine got the vibration like said when doin the balance delete... then car starts to struggle to stay on and dies then it doesnt want to start, i pulled codes...1st- 25? with D4 blinking 7? then i reset the ECU then it threw a 20? now its just 20. isnt that the map sensor and would that cause the car to struggle to stay on and die?
motor doing wierd things need help asap
Yes the map sensor can cause your car to struggle to stay on ad die.
A bad o2 sensor can cause that as well
When I read the post title I thought your car was doing backflips or something
Last edited by konig52r; 10-19-2009, 05:01 PM.The past, is history:The future, is a mystery:The present, is a gift.
James 4:7
Submit yourself to God. Resist the devil and he will flee from you.
doin backflips would be awesome i wouldnt complain its like having a retarded transformer!Originally posted by konig52r View PostYes the map sensor can cause your car to struggle to stay on ad die.
i adjust timing with the dizzy correct? if so i did that and anyway i turn it, it does do anything(i dont think) and i looked at the hose that goes to the map sensor and i gotta replace it some how that shit ripped it looks like it was cut bfor i even got the car...Originally posted by MR.PHIL View Post
@ Retarded Transformer .
adjust your timing ,that surely can be the cause behind your problem
ding ding ding.Originally posted by sleepygreen View Postredid timing<-- im sure its off by give or take 2
that could be it huh? i fixed the hose to the map sensor and it starts and runs fine but still has high idle and when i smash the gas it boggs badOriginally posted by fatboy1185 View Postding ding ding.
