Another Blaster SS Coil Problem....
    Hey guys I tryed Removing my Stock External coil and adding a msd blaster ss coil that I got for free from a friend. After the swap was complete I went to start it and had no spark..
    My question is do I have it wired correctly????
    I cut the plug off of stock coil, put the yellow wire to the POS on the MSD Coil and took the other TWO black wires and put them to the NEG....Is that correct???
    If not what is the correct way to wire it up??
    Thanks!!
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
    I think I cound possably have a bad coil...It is used and been sitting around..
      bump for wiring info....
      PS I have no MSD 6A or 6AL Box im using just the Blaster SS Coil..
        man im getting no love today....lol
          Hmmm. thats how i did it exactly how you said...check the wire inbetween coil and dizzy cap!
          EDIT: new thought check connections and solder wires... do you have those wires going directly to coil from where you cut /or added wire to length?
          I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
          My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
          Oja Thnx Everyone, at cb7tuner.com
            is it possible you need to run ballast resitor? MSD part number 8214
            i know the internal coil to external swap you need one when using an aftermarket coil. without it will take out distrubutor components. you can take out the ignitor with a aftermarket coil if no resitor is in line. this info is relevant to internal coil setups swaped to external.
            hope this helps
            96 Accord SiR driveline installed. CF2 donar
              I didnt have to add any wires I just Cut, Striped and Clamped Fitted Ends on the wires then Hocked it up and I got no Sparky!!
              I'm going to try a new Blaster SS Coil Friday I'f That dont work I'll Start looking into a ballast resitor..
                hope this helps
                i didn't use one and mine worked great for over two years
                OHIO CB7's
                My Ride
                MOD FUND: better if I could sell some of my stuff.
                Build Thread
                vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
                  And you wired it the same?? Yellow to POS and the TWO Black wires to NEG????
                    the distributor could have failed too. either way try a known good used distributor if some will have one around, or a coil for that matter
                      ballast resistor was only for cars with points ignition systems.
                      why do you have 2 black wires?
                      if u hook it back up normally does it start?
                      Retro!
                      Hater
