How to remove the big amp under hood fuses?
    My blower motor is not working so I checked the 30A fuse in the engine bay. I can't really tell if its blown or not so I just wanted to swap it out for another one.
    However, I can't get it out. I tried pulling really hard and even tried a gentle tug with pliers but ended up breaking off the plastic.
    Is there a trick to removing these 30A, 50A , 80A fuses from the engine bay?
    1992 Accord Coupe 5-Speed
    they are screwed in.....
      Thanks for the quick reply. I saw those philips screw heads but was like "why would a fuse be screwed in". I've removed high amp fuses from Camrys and they were the regular push/pull type.
      Thanks for confirming. I appreciate it.
