Double Stack Bolt Kits??
    Who other than BlackTrax Sells the blot kit for double stacking 2 IAB Plates?????
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
    Any hardware store.
      Originally posted by HondaFan81 View Post
      Any hardware store.
      Yea I know that but I was wondering if there was any retailers putting out a kit like BlackTrax...
      I dont really have time to go to the hardwear store and Pick and Poke at nuts and bolts....I work 7am to 7 pm 6 days a week...Sucks!!
        Call blacktrax and ask for the bolt specifics (size, thread,length), and go knowing what you need. I also believe someone said the a/c compressor mounting bolts will work for this setup. You could unscrew one of those and walk in and match it. shouldnt take long. Maybe that is for a single plate. There are threads on here concerning this. I just dont have time for the search. I'll check it out later.
        My inferiority complex isn't as good as yours.
          I like your Style...LOL
            But you have time to be on this forum? That's an excuse and you're being lazy, does not take long at all. It's called planning and I work more than you do.
            If you don't have time to get the hardware, how do you even have time to install the whole setup, let alone any other more significant mods.
              I like ^his style.
              Like others have said, it doesn't take long. But since you work so much and don't have time to search the forum I'm going to give you the answer. You are going to need 8x1.25x100mm bolts.
              Hope this helps.
              1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
              2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
                funniest thing...i like ^^his style...i can understand though the OP's aggravation with going to a hardware store. i used to work at ACE and little kids will put bolts and everything in places it shouldnt be. Most of the time though they keep it pretty clean so yeah im going with the "excuse" motion too.
                  Originally posted by CB7/KA8 View Post
                  I like ^his style.
                  Hope this helps.
                  8x1.25x100mm
                  I am hoping that is it man.
                  But lowes and auto stores do not carry it.
                  I am hitting up a nearby fastner store.
                  still need to verify these sizes, but will know shortly.
                  MadLab Racing
                  Southern Maryland
                    Metric stuff can be a pain to find. Home depot doesn't even have a lot but I know Ace does. the hardware company is called Hillman and they will have everything you need. Aldo check your local junkyards if you do ever find the time. That way you know what size it is you need
                      they are the same size bolts that hold the ac compressor to the bracket.
                      member ride thread
                      DIVULGE MOTORSPORTS
                        I was putting my double stack together today. I have a6 runners, and h23 plenum, 2 IAB's(one gutted). 8mm 125 x 100 mm bolts work on the 2 corners closest to the valve cover, but the other three bolt need to be shorter. Somewhere around 80 or 90 mm. I have to get 3 more bolts tomorrow. The 100mm sticks too far through the plenum and IAB's exposing all of the threads, and couple mm of the shank, and it bottoms out in the runners before you run out of threads. The only way I could use the 100mm is to have a big ugly stack of washers. I dont know about the a6 plenum but mine needs 2; 8mm 125x 100mm bolts, and 3; 8mm 125x90 mm.
                          Nice.
                          Time to hit up the junkyard and unbolt some AC compressors
                            I thought the bolts you needed were off of the ac compressor on a Prelude?
                              I took a couple of pics. One shows how much the 100mm long bolt sticks thru the h23 plenum, and 2 IAB's. The other shows how much thread is left when the bolt is screwed into the front center mounting hole in the a6 runners. Would need a stack of washers to run 100mm bolt in 3 of the plenum mounting holes with a double IAB stack. 100mm is perfect on the corners closest to the valve cover.
                              The last pic is me.
