Car not starting.
    Car not starting.
    I recently removed my distributor to fix an oil leak in my 90 accord, but after i fixed the leak and but back on the distributor my car now those not wanna start i dont know if the timing is now off or what van anyone give me any suggestions on what i need to do. I hope someone can help im going crazy not being able to drive my baby.
    check your firing sequence of your spark plug wire. you might have it mix up.
    check hayne manual for sequence
      I checked the sequence like 4 times still nothing.
        Perhaps the rotor got spun 180 degrees when reinstalling?
          Since you have an internal coil, MAKE SURE the spring that bridges the cap to the coil is seating properly and check all the connections inside the dizzy (coil, ignitor/ICM) for corrosion. I had a starting issue w/ a friends 92 Civic 4dr w/ internal coil B18A1, had spark and all, but the coil spring wasn't seated correctly. Took the cap off, put it back on, bam, it started right up. It can be the simple things sometimes that you can overlook so easily. I was on the phone w/ HondaFan81 for awhile thinking the problem was way more serious and it wasn't
            do it the russian way
            http://www.youtube.com/watch?v=OIh78GiTqrE
              As soon as the sun comes up tomorrow i will go check the spring, hopes thats all it is.
