Exhaust Gaskets
    Exhaust Gaskets
    I am currently running a generic header setup on my F22a1 and a generic resonated "test pipe". I need gaskets: the one where the header meets the head, the y-pipe one, collector, and the one after the "test pipe". And suggestions out there for good brands? I know theres copper ones, aluminum, and graphite, which are the best? im willing to dish out money for good ones cuz im tired of leaks!
    You really don't need anything fancy. Just a proper OEM gasket should work fine. I believe www.tasauto.com has some good ones available.
    Why a test pipe instead of a cat?
      Also your local muffler shop should have it.
        Muffler shops may or may not have quality, though.
          I was only $20 for the pipe and i wanted to see if it made a difference in power but i didnt so when i do get money for a high flow cat im going to get one lol.
            Oh i was gonna ask if an H22 header gasket will fit an F22 header (the gasket thats between the header and head)? I heard its the same but im just double checking.
              Well the F22ax exhaust ports are like this: 0-0-0-0
              And the H22ax exhasut ports are like this: 0-00-0
              You can't really tell but thats how the H22a exhaust ports are.
              And the downpipe......I woulden't know, you would have to wait and see what other members on board can tell you, since I have an F22.
              Good luck
                Good luck
                Oh ok thanks for the "diagram" of the ports lol. I'll have to do somemore research !
