BB4 compatibility?
    BB4 compatibility?
    Just wondering to know if suspension from a bb4 will fit a cb7 without modification?
    yes the prelude suspension will fit with out modification.
    my new turbo build
      Thanks
        I thought the fronts only fit, not the rear.
        When you find out for sure, can you update this thread?
          if ur not to sure go to ebay and compare. im pretty sure that they are interchangable.
          my new turbo build
            No they are not.
            wat?
              Well aparently only the front suspension will work, I searched a little and the only post saying it, was this one:
              Originally posted by sleepycb7 View Post
              i know this is kind of a old thread but the prelude front suspension will fit. i just got done swapping the front crossmember, radius arms,lower control arms, spindles and tie rod ends. it all fits. the inside mount for the lca on a accord is slightly smaller than the preludes so a little bending is needed, only about a 1/8 inch or less. the prelude lca is longer, wich is why i did not use the uca. a camber kit is necessary for proper alignment.it did make the track of the front wheels wider but not by much. have not driven it much (no time) so i cant tell a handling change. took some pics. enough to do a diy if anyone wants? got all the parts for free so it was worth it to me. btw all 96 lude parts were used. i think base 97-01 prelude spindles will work though, if u wanna do 5 lug!
              you can check it out here: http://www.cb7tuner.com/vbb/showthre...03#post2284603, altough it doesn't mention anything about the rear suspension.
                rear wont fit to wide
                Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
                CLICK THE PIC
                  Just use a proper suspension. Even if it fits, it's not the right thing to have.
                    Point well taken. I'll just wait hopefully the place I found the bb4 suspension at gets more cb7 suspension.
