I have an F22A6 and have been looking at what others are doing to intake manifolds,which intake manifold should I get to bolt up to my F22A6? I have found 2 close to where I am only problem is dont know which one to get, the Prelude 2.3L or the Prelude 2.2L V-TEC they have both....please help.
Which Intake Manifold to get,F22A6
you can get an h23 IM or just keep the a6 IM which flows very well alreadyYou don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
The H23 manifold is a significant upgrade. The H23's plenum will bolt to the lower half of the F22A6 manifold, which is supposedly the best combinaton... but that's only a theory, as it has never been tested on a dyno.
As for a short ram, the pipe doesn't matter... but the filter does. You're going to want a proper AEM or K&N filter. You can get a cheapie pipe. That doesn't matter at all.
A6 with a bit of cleanup would be best. Your efforts with an H23 most likely wont be rewarded unless you're doing a serious build. However, you could do something crazy like have an adaptor plate made to make a Euro R or one of the fancy K20 manifolds fit. I just had an adaptor plate made for my F23 to H23 IM. With CNC and an aluminum 3/8" plate you can do pretty much anything.
Originally posted by deevergote View PostThe H23 manifold is a significant upgrade. The H23's plenum will bolt to the lower half of the F22A6 manifold, which is supposedly the best combinaton... but that's only a theory, as it has never been tested on a dyno.
get an h23/h22 throttle body and plenum (the plenums are very close to identical) and add a gutted IAB plate or blacktrax spacer under the stock one. this lengthens the runners which is good for the lower end power of the f-series. for high-end power, remove the IAB plate and bolt the h23 tb straight to the runners.
Originally posted by xkjnboix View Postthe f22b or a ( i cant remember ) has a much bigger tb bore than the h series. research it
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
