Question about lights
    Alright so i purchase some JDM Smoked tailights from an online source recently and i am having trouble getting the bulbs to light up. Basically the smoked lights only have a housing for 1 bulb each on the middle lights. They gave me a socket with 2 wires to connect to the harness and go into the housing, and basically when i put the bulb in and connected it to the harness and tested it, it wouldn't light up. So what i tried putting the bulbs back in the original housings and they wont light up at all, although the others still worked. I checked the bulbs they still appeared to be good. Could it be the connector from the harness or from the socket are not connected properly? i also checked the fuse for the brake lights and it was fine. Any help would be greatly appreciated
    that's most likely the culprit. I'd just look over the new harness and check where it could be pinched or check down and see if the connectors are jenky.
    Life's a garden. Dig it.
      Sound like the new harness..Try to switch them to the other side to see if it work if not send them back.
      btw, sounds like aftermarket not jdm.
        well i did try switching sides and still no luck, so im thinking maybe i just go and get new bulbs anyways before i send them back, since bulbs are like $5 for a pair
