when my car is warmed up, it adles perfect, but not when its cold. it will jump up and down, sometimes close to dying. no vacuum leaks. does this point to one thing that could be bad (IACV or something) or could it be a number of things?? thanks for your help
lopey idle when cold
2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride ThreadTags: None
try cleaning the iacv. there is a diy on it.Originally posted by theSOB View Postwhen my car is warmed up, it adles perfect, but not when its cold. it will jump up and down, sometimes close to dying. no vacuum leaks. does this point to one thing that could be bad (IACV or something) or could it be a number of things?? thanks for your help
clean or change the fitv... its the valve right next to the iacv...OHIO CB7's
My Ride
MOD FUND:
better if I could sell some of my stuff.
Build Thread
vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
my girl will start and be around 550-700 rpms warming up, i dont think it lopes tho, maybe try adjusting the Fast Idle Thermo Valve before removing it.
You could also try raising the idle just a smidgen.
Originally posted by SE_DynamiKL M F A O !! Here's some advice: if you want to run 14's, don't sit at the light for 3 seconds after it turns green.
thanks. it never did it in the summer tho. just started recently. in the summer it would idle somewhat high, around 1600, until it warmed up. but it was steady. this is just weird. i usually do not drive it in the winter either. so idk if this is 'normal' for my car2013 Ice Cream Cruise!
By 1320 Video
That's the key symptom of a bad fitv. Clean it, adjust it, see if that helps, or replace it.
Sounds like you may want to turn the idle screw up a smidge too.
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
