Brake problem!!!
    Brake problem!!!
    brake pedal is going to the floor starting out doing it everyonce in a while but has progress to where it just wants to go to the floor and lock up the tires, which has made the car undrivable at the moment. Ok i have full fluid and not losin any..i checked between the BMC and Brake booster and didn't see any leaks...help?
    4 door pimpin'
    not sure of this but could be the master brake cylinder.
    I could be wrong.
      im kinda waiting on advice from fellow cb'ers lol..before i go drop a stack at the parts store lol
      4 door pimpin'
        Most threads I've read regarding sinking brake pedals have been due to the Master brake cylinder. wait for the guru's to chime in tho
        1992 Honda Accord Coupe LX
          yeah that's what i was waiting on, i just didn't kno how to go about it, maybe BMC fail internally too..i did some searchin but couldn't find anyone that had the exact same problem.
          4 door pimpin'
            Either:
            a) Air in the brake lines (try to bleed the brakes to rid of air in the lines.)
            or
            b) Faulty Master Brake Cylinder (with the car off, pump the brakes until the brake pedal feels firm and hold. If it's faulty, the brake pedal will slowly descend to the floor.)
              a way to find if its the master is, car off,have some one pump breaks and start from the passenger side rear,bleed it.if the squart is weak.then its the master.
              my new turbo build
                it's the brake master cylinder. you won't see leaks from it because it leaks internally. later.
                Avoiding dirt at all costs
                  def. the master they go out lil by lil
                    Brake master cylinder. I had this problem before it just goes to the ground after press several time. I would do this soon as possible. Manual braking hurts.
                      look at the dates on the posts ...........old
                        lol
                        Another easy was to tell if the BMS is bad or going bad is to look at the booster. The booster is painted, brake fluid doesnt like paint. Brake fluid leaks on booster...eats paint.
                        Your man for wiring solutions!
                        CB7Man's Coupe H22 Swap
                        CB7Man's Sedan Resurrected From The Dead
