Fuel Filter
    Fuel Filter
    Currently I'm replacing my fuel filter. There're two washers on the line going to the fuel rail but in the bag there is a third small washer and I don't remember seeing one of those when I took the old one out. Where does this go? Or do I not need it? It's a purolator filter.
    use the two washers..they give you third for spare...easy to loose I guess..when I did mine it came with three also.
    http://www.cb7tuner.com/vbb/showthread.php?t=121793
      it's been a few years since i've replaced mine, but i remember only needing two washers.
      make sure you use a flare-nut wrench for the fuel line fitting, otherwise you can round out the nut. later.
      Avoiding dirt at all costs
        Yea I used the proper wrenches. Coudln't get the bolt that clamps the filter to the firewall back on but it's pretty snug. No leaks so that 3rd small washer (smaller than the normal 2) must not be needed.
          I am replacing my fuel filter right now and I am wondering about that 3rd little washer, too. lol Anyone have an answer for where it goes?
            if i remember right it goes in the banjo connection one on the inside not sure if you understand that. lol.
            Yes my name is Dang, Don't use in vain
            1992 Honda Accord EX (Coupe/Bordeaux/Auto)
            1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
            2008 Honda Accord EXL (Coupe/SanMarino/6spd)
              Isnt it for replacing the one on the fuel rail, that you undo to de-pressurize the system.
