motor mounts?
    motor mounts?
    can you refill our motor mounts with new rubber/urethane or do they have to be replaced?
    any options that arnt 300$ other then stock?
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    http://www.cb7tuner.com/vbb/showthread.php?t=118013 hope that helps.
    my new turbo build
      motor mounts arent that expensive, not even near that.
      Retro!
      Hater
        Hit up ebay... I've been running ebay mounts for about 10k miles and have had no problems what so ever. And if I remember right they were less than $200 for all 4.
          look on tasauto.com for some motor mounts
            The OP is not looking to buy new mounts. He stated that he wants to repair the ones he has now, which will be cheaper. Follow the DIY.
            Past 1990 Accord EX Sedan
            Past 1990 Accord LX Sedan
            Past 1991 Accord LX Sedan
            Past 1993 Accord LX Wagon
            Current 1991 Accord EX Wagon
              x2 I should be doing this DIY soon
              MY H22 SEDAN
                thanks yeah that DIY looks pretty straight forward and cheap..
                ill get the true solid poly ones when i do my h swap but until then i think this will work great. thanks guys
                  now th op in the DIY's mounts were cracked my front one is completely broken can i still fill it?
                    you can also get the poly inserts and not have to worry.
                    Retro!
                    Hater
