upgrading fuel system for turbo
    as far as injectors, fuel rail and fuel pump what works and what dosnt any suggestions?
    It depends largely on what turbo setup you plan on running.
    If you plan on boosting a stock-block F22A, then you can get away with using 450cc injectors from a 1st gen DSM (eclipse, talon, laser). They go in with minimal modification. You will need a modified and tuned ECU to control those injectors, though. The stock ECU won't know what to do with them. This goes for any non-stock injectors.
    The fuel rail flows just fine. You won't need to upgrade that for a very long time. A stock-block turbo setup will never need a fuel rail upgrade. If you want one anyway, AEM makes a good one.
    As for the fuel pump, the Walbro 255lph pump is one of the most common choices.
