CEL on
    CEL on
    CEL comes on after aobut 5 min of driving or warmed up...
    changed the O2 sensor on manifold less then 1k miles ago same with cap and rotor and plugs and wires...
    could it be the sensor on the cat?? or wherever the other one is little help would be much appreciated.
    Sooo...im gonna assume you've already done the CEL diagnostic? Because it would've told you what it could be.
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
      http://www.cb7tuner.com/vbb/showthre...hlight=cel+diy
      U didn't mention if u checked the CEL . If not read this link and let use know
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
        Checking the codes should always be the first step in diagnosing.
        Just curious. You have 2 O2 sensors? What year is your car? I thought that was only the case for OBDII cars.
          From what I read in the Hayne's manual, an o2 sensor doesn't start sending a signal to the ecu until it's reached 700 degrees, I believe. I was having the same issue in my car, as soon as I started my car, the cel came on, it was throwing an o2 sensor code, so I bought a new sensor, come to find out, it was the ecu. Replaced the ecu, no more problems
            We have 1 o2 sensor. From what I have read our cars are also picky about the brand used too. NGK/NTK are OEM and do well.
            3 CB's gone....
            1 WK Overland....
            Still miss the CB though......maybe one day.
