Timing Belt Kit?
    Timing Belt Kit?
    should i buy the whole kit or just the timing belt itself?
    imo i would buy the kit...
      What does the timing belt kit you're refering to include? You should replace your water pump while doing the timing belt, and while your in there whynot do the alt. belt and acc belt.
      Bought From : SE_DynamiK, oneoffaccord, and TopCop182
      Click It!>>>><<<<Click It!
        Buy from Honda or TASauto.
        The timing belt, water pump, all associated gaskets, and possibly the tensioner should be replaced.
          yeah like Deev said..your down in the shit so you might as well replace it all..makes sence and cheaper in the long run.
            Plus, if your tensioner fails, it's as good as that brand new belt snapping. If your water pump fails, you could overheat and do lots of damage.
              Ok thanks i might buy the whole kit, But i Called honda a while ago and the guy said they dont have a timing belt kit. I think they want me to buy it separately. But thanks for the reply guys....
                Buy the timing belt kit from TASAuto. Even their non OEM Honda kit is high quality.
                Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
                  Honda NEVER sells "kits". Honestly, you should know what you need to install, and be able to buy it separately. Not buying the right parts because you want to get a "kit" is simply being lazy.
                  I do agree. TASauto is a small company catering to the Accord market ONLY. For that reason, they carefully select the parts they sell. They don't sell junk... or they wouldn't be in business! CB7tuner also fully supports TASauto, as you can see by the banner at the top of the page.
