power steering!!!!
    power steering!!!!
    does anyone make a power steering delete? My power steering is leaking and I just want to get rid of it. I was thinking of just taking to pump out but wouldn't that mess thing up? like dry rot seals and so forth?
    The correct way to do it is get a manual rack from a car that doesnt have ps other wise u run the risk of ruining your current rack. Maybe you could remove the belt/pump/lines and then cap off the rack to have a "manual rack"
      http://stealthmodeperformance.com/
      You may want to look into how these kits are made and come up with your own. I'm actually thinking about doing the same thing. There's tons of members on here without their ps though. Search around through the MR section and search for power steering removal diy or something. You should find something that'll help.
        A few people I know have just looped the lines, and kept fluid in the reservoir. I currently have my belt cut, but the pump is still in place. I'll eventually be looping the lines as well.
          I think I am just going to cap off the lines. what is the whole reason for people capping off the lines then leaving the reservoir on?if you take the reservoir off there should still be fluid in there.... right?
            You want there to be enough fluid to lubricate the rack.
              I bought mine without power steering I added it right away but the rack is really screwed up the damage was done
              1991 Honda Accord EX
              Short Ram Intake
              APC Exhaust
              http://www.cardomain.com/ride/2682565
                My last rack was acting messed up and i cut the belt.I switched it out for a 92 ex rack and never got a belt, so i just hooked it up and run it with fluid.Its been 7000 miles and ive had no problem. I actually cant wait to get a new belt and have P/S again. But you should have np as long as there some kind of fluid in there.
                90 Panda DX F22A6
