92-93 Heater Controls in a 91'
    Ive broke my upper heat control slider today, and was wondering if the nicer push button Automatic controls bolted right in, if so what would i need to install them?
    Thanks for any input.
    Originally posted by SE_DynamiK
    L M F A O !! Here's some advice: if you want to run 14's, don't sit at the light for 3 seconds after it turns green.
    Harness is different - need to rewire them to function. There's a thread somewhere discussing more detail.
      good god almighty, wheres this thread about the auto controls install. Searching and nothing!!!
        find a LX or EX and swap over.
        wat?
          ex has push button
            Yeah ive found the one im wanting to install, but....im trying to see what is needed for the install....is there a motor that changes the venting options, and a wiring diagram that could be used
            This cant be the first time this would be attempted. This has to be documented somewhere. hope so.
              search masters UNITE!
              I still cannot find anything remotely of use, even used google. lolz
                I want to do the opposite, lol.
                They are different and it does require some extensive rewiring and such. I think it has something to do with a cable or wire ran system.
                Originally posted by Jarrett
                  just a thought ..could you use a wireing harness fron a ex/lx for the dash and the controles for the vent,ac,hot water suply ..could that work? i would like to do it to
                    probably will need to swap everything over from a lx/ex as the dx is very primative. by moving the slider for the direction of the air you physically move channels in front of the blower whereas the lx/dx seems to be controlled by electronics.
