How hard should it be to turn the motor over by hand?
compression
should be easy till just before tdc on the compression stroke of that cylinder...then it gets a little tough, then it rolls over almost on it's own.
You should be able to do it with a regular length 3/8 ratchet it should not require a long 1/2 breaker bar.
normally you're actually turning two compressing cylinders, you were turning one. With the plugs ALL out...super easy
sounds like you're fine.__
__
no but really im assuming you took the plugs out? otherwise... not real easy on a compression stroke...
