Polishing Intake Manifold
    I never got that much info on it. My friend basically said "sandpaper smooth is ok"... as long as you don't polish to a mirror finish, it should be alright. I haven't done much of my own research here, though... so I'm really just regurgitating what I've been told. My sources are credible, but my own knowledge is limited.
      Heres the site I read it from. Its the 9th paragraph down. Starts with Polishing. http//www.importtuner.com/tech/0703_impp_engine_heads_and_valves/head_work_terms.html. It talks about the terms used when getting headwork done. I found it to be informative.
        why not just paint it silver alloy? Thats what i did with my manifolds in my 300zx. came out looking like stock, but had a nice shine.
        Retro!
        Hater
          I'll get some once I go home this weekend. It's not done yet though.
            rough would be a 320-400 finish or a beadblasted finish.
            if you take all the sensors off, you could probably "tank" the upper portion. probably a good time to clean the egr ports as well.
              all the sensors are taken off already. i'm gunna end up blocking off all of them except the IACV. I am also blocking off the EGR so no need to clean the ports
              2013 Ice Cream Cruise!
              VIDEO: 2012 Ice Cream Cruise
              VIDEO: 2012 Ice Cream Cruise part 2
              The single largest cruise in the Midwest!
              August 3 ~ Omaha, NE
              By 1320 Video
              Member's Ride Thread
                You might not want to do the upper part.
                I believe it's more of an acid bath. I have an H22 block that was tanked. Nice and clean. Well, it was... it's been in my shed, so it's not so nice anymore.
                Technically, it's not an acid bath if it was used on an aluminum block. The typical acid used in an old school "hot tank" would eat the aluminum alive. I'm not sure what they use, but it's likely just an extremely aggressive solvent, not an acid.
                  yea, in our hot tank we cant put anything aluminum because it will oxide it in a heartbeat. All aluminum goes in a different washer.
                  one time i accidently put my finger in the hot tank and it burnt the shit out of it. 180 degrees + really harsh solution = bad times.
                    I'm currently polishing mine...it is hella time consuming too, lots of nooks and crannies.
                    I am following typeg's methods...search...lotta info...his shit will blow your mind.
                    I've gotten mine shiny...but mirror finish is what I really want...and I most likely won't get there.
                    I started with 80 grit and I will work my way to 2000 when done, then more with polishing wheels. I've gotten to 600 grit right now and it looks good (no pics).
                    ____
