Fog light removal?
    Fog light removal?
    I need desperately of your help, I think Im gonna have a chance to buy some Oem fogs but i've looked everywhere and don't know how to tak'em off tha car.
    Please if you know about it let me know.
    Thanks in advance
    Colombian CB7
    http://www.cb7tuner.com/vbb/showthre...3A+1992+accord
    I'm guessing that you'd need to take the actual front bumper off.
    Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
    Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
      Thanks!
      And what about the wiring until the switch? How do i take that off?
      Colombian CB7
        each foglight has a harness pigtail. You can disconnect them, and the wiring harness goes up behind the headlight, attaches to a bolt (10mm i believe) then runs along the fender into the firewall. From there, there are 2 wires on the fuse block, and a ground. Then, they run over the steering column and into where the switch is above the radio.
          Thanks very much mj213, I guess I need all the wiring in order to hook it up in my car, well with these instructions it might be easier!
          Any other thing to take care of?
          If not, Thanks again!!
          PS< I love your Cb by the way!
          Colombian CB7
            in order of taking off the switch you got to take off the whole base i 4got whats it called, but theirs 2 screws on the tachometer (on top) its hard to see them from the front so you got look up so you can b able to see em... i dont kno i broke all that took out the switch and then the wiring but it was at the JY
            AT WEST COAST MEET
            cb7rush: who has the tongs?
            JDMxDB8: i got a thong on...
            to get to see more of my cb click the link below.
            http://www.cb7tuner.com/vbb/showthread.php?t=130922
              http://www.lesterdelacruz.com/foglig...3%20Accord.pdf later.
                http://www.cb7tuner.com/vbb/showthre...e+face+removal
                ^^DIY for dash panel removal. i've never dealt with OEM fog switch so idk if you gotta take the whole panel off or if you can pop it off with a flathead screwdriver. got pics of the switch?
                  you dont have to take off the who bezel to take the switch off you can just pop it off at the bottom with a flat head and unplug the pigtail and just pull out the pigtail under. its just like taking off the block off plate that was there. just pop it out but becarefull not to damage it.
                  MEMBERS RIDE.
                  Bought from: DannyD , Night Wolf , CB7=91, lummieCB7
                  Sold to: LITuner, rezist09, Pacman91EX, 93AccordLXwhite, PhatAccord, TheNextEpisode
                    Thanks a lot, I was wondering about that, I don't need to take the whole thing off, since the wiring might come out just by removing the air conditioner control, well in that parat I`ll be able to sort it out since I've taken mine off like 4 times.
                    Pedro alcala thanks for the pdf, really helpful!!!
                    Colombian CB7
