Another problem. Power steering pump
    LOL I gotta laugh because if its not one thing its another with this car.
    My power steering pump is leaking. not from any hose but from the top, kinda where the bearing is. I suspected some leak but couldnt tell where untill i wash the engine bay.
    Any fix to this apart from buying a new one?
    Wash the bay and see where its coming from.
    had this problem, turns out that the pump was bad and I had to replace pump and belt.
      I see where its coming from. On the pump where the belt "wheel" is, there is a likkle piece with a couple of bolt. as you look at the pump directly, there is a crease/crack. thats where its coming from.
      I am here wondering is tightening those bolts will do anything.
        does your resivor have bubbles in it?? if so you can goto autozone and buy a powering steering pump reseal kit.... they have it special order like 17 bucks. thats what i did with mine, i knew that it was leaking but i could find any leaks, except the bubbles..
          so while the car is running, i should open the cap and look?
            i would just take the power stering of it is a lot easier to just leave it
