does nitrous do damage
    if i were to buy a nitrous kit on my car would i do damage to the engine it has 200xxx miles?
    plz i need advice on this
      That truly depends on the health of the engine in question. But there have been instances were a 50 shot is ok. Also to maximize your gains, look into the Bisimoto 2.4 nitrous cam.
      Bisimoto Engineering
      1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
      2) Email me, robert@bisimoto.com
      3) Contact me on AIM, robert@bisimoto.com
        around a 25 or 50 shot or so would be safe, i wouldnt go too crazy even on a newer engine, i wouldnt go higher than a 50 shot
          ok and do u kno if they are hard to instal im really wanting to mad my cb7 kuz its deppresing me that its stock lol .
            lots of info here: nitrous forum and a few people have run as high as 100 shots on their f22s
            96 mx-6, needs work...
            91 accord lx sedan, needs work...
              your motor is ok as long as you take the steps needed to run nitrous. like getting step 1 colder plugs, retarding the timing as needed, and running 93 octane. taking these steps will allow your motor to run smoothly without issues. just as long as you use the nitrous PROPERLY.
              dont spray while your shifting gears. make sure theres a switch to arm/disarm the system. you dont want to start your car up with a cylinder filled with nitrous because someone in your car accidentally pressed the button. i do believe ZEX has the system(and others i think)that only sprays at WOT.
              taker a look in the nitrous FAQ in the performance section. there are PLENTY of threads in there to help out. if you have any more question, PM RICHIE*34GTR, myself, or 90-JDMCB7
                if you buy a well known kit it should come with instructions, a dry kit is the easiest to install, i recommend the zex smart nitrous kit. its very easy to install and very user friendly
                  can i put nitrous even if its automatic ????
                    yep. doesnt matter about the transmission. just make sure you change the fluid regularly. use only OEM ATF from Honda.
                      oh ok so its semi easy setup and its not to exspesive rite . plus it will give me that extra boost ?
                        i would have him help you .. you can call on the phone
                          its the cheapest power you can buy
                            ok sounds gud to me . the problem is where to buy it ?
                              how is that a problem- ebay, autozone, o-reilys, advanced, local speed shop, craigslist, the internet is at your fingertips
