chipped ecu blues
    chipped ecu blues
    hey guys. i have been running a chipped p06 for a while now. only recently in the morning it has been colder than cold. in these mornings my engine will either not turn over or wont stay running more than 2 seconds. i try and try until my battery is on its last strokes until i always have to resort to putting my stock ecu back in. it starts right up everytime.
    in the afternoon when it warms up outside i put the chipped ecu back in and it starts no problem. granted i do have a code for my eld, but i dont feel that could be the problem.
    any advice?
    Andy.
    ^^click it or ticket^^
    if it wont start with the chipped ecu but starts immediately with the old one i would have to say the problem lies with the ecu
      What sort of tune are you running? Is it tuned for your car, or a generic tune that you got from someone?
        closest map I could find to a stock f22 map.
        Got it from D112crzy. So I figure the tune if fine...but maybe the cold ass weather required moe fuel for start up which it is not getting?
        I'm not too sure.
          um, easy fix. if your car doesnt start with the chipped ECU, DONT USE IT!
            I'm guessing the cold start up issue has to do with the ECU calibrations/tune. Not an uncommon problem.
            Look in the ECU tuning section and PM one of the more knowledgeable tuners. If you have the equipment, they can lead you or you'll need them to tweak and resend a calibration for you.
            Deev makes a point, in that if this tune was actually done at a local dyno, all this would have been taken care of and done correctly for our environment. Should you be running this chipped ECU, if it is not tailored to your mods (if any)...which is what you're indicating?
              Post your bin
              It may be bennificial to post your bin file. You can do that on here, but there are only a few people on this site that actively tune. I would suggest posting this on pgmfi.org
              201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
