90 accord Rough Acceleration help
    My car is an auto at 200k,rough accel from start to about 25mph,then gets into gear and runs smoothly till I come to stop this repeats itself over and over,talked to mechanic he said ,I don't have 1st gear.I need a second opinion please?Could it be motor mounts?Do I rebuild or replace tranny if so,what should be a good estimate?bought last yr,has timing belt done but aome other minor issues in waiting.
    Have you tried to check your ignition timing, timing belt alinment, rear balancer shaft alinment, clutch system flush/leaks, release fork play, etc ?
      your an idiot.
      Most likely the auto tranny is going out and its slipping in 1st gear.
        is your d4 or 2 light flashing. if so could a couple of problems. trans control unit for shifting problem & rough accel could be wires or egr ports clogged.
          ok so its the tranny going out,and it is slipping,does that make me an idiot(reccakun08)?
          You are probably an angry infant who got his toys taken away.Grow up.
            mine used to do the same, after a full tune up, and transmission oil change, everything ran smooth
            maybe it just needs a tranny oil change.
            view my ride: My Ride
              Thanks a lot,I will do a tranny oil flush on monday,I love my cb,but I have been steadily fixing stuff on it,timing belt and intake manifold have been changed early this yr,also had cat converter changed granted now she is at 200k,not to help things my new JVC head unit was stolen last week,just replaced the power steering pump,belts and fluids.If I could find a decent tech around where I live I would probably keep her.she has been solid reliable for the past four yrs.
              If it doesn't turn out to be tranny fluid,I wonder if I should rebuild or swap?
                I am for sure its the tranny
                  yeah it sounded like it. i guess if you are wanting to do a 5spd now would be a decent time.
