ECU Help
    thank you all very much
    especially for correcting misleading information, <3
      The F22A's distributor can only advance or retard so much. You really won't gain all that much from advancing and running higher octane. I have been told (never been willing to try it) that you can advance to the maximum amount physically allowed by the distributor and it will not damage the engine.
      i have tryed it to get the launch correct where i race (1/8 mile drag) and i have mine all the way forward clockwise just to get the power band where i needed it. i have been testing this for a while and had no problems what so ever going either way it just moves your power band ..i tune on 110 octane wich is to much for my car but it runs so much better and cooler with it and not to give any one bad advise but if its just a toy to play with like my car (NOT a daily driver) it is so worth trying. i have cut my launch and times in half doing this plus a c/a/i and the open exhaust so worth doing but that is just me and i got my CB7 for free so every thing i do is an experiment with it..
        That is true... if you're willing to blow it up, then experiment all you want. Don't experiment with the suspension or brakes, as that can be dangerous... but a blown motor is just an inconvenience. If it's a toy, and you can afford to replace the motor... then anything is worth trying.
        Hell, I bought a beater DX that ran strong, but had messed up body panels due to rust and a sideswipe. Still straight, but not pretty. I had indended to boost it and blow the motor running a tiny T25 snail... I cheaped out on the tires, though... only replaced the fronts. Lost traction in the rear during an ice storm, and spun into a wall. Drove it home, parted it out, and junked the chassis.
          do you know how many degrees camshaft rotation that would be on an adjustable cam gear? i'd like to try this out sometime. do u always have it set to that when you drive, or just on race day?
          2013 Ice Cream Cruise!
          VIDEO: 2012 Ice Cream Cruise
          VIDEO: 2012 Ice Cream Cruise part 2
          The single largest cruise in the Midwest!
          August 3 ~ Omaha, NE
          By 1320 Video
          Member's Ride Thread
            Camshaft adjustments should be made on a dyno.
            Bisimoto's cam gears have 6 degree adjustments.
              i have the skunk2 i picked up a while back. been considering gettin the one from bisi to replace it
              By 1320 Video
                mine is set there all the time .. as i only drive the car to the track , race and then take it home so that is about all i use it for. On an adjustable cam gear i have no idea what the difference is. BUT giving fair warning this is not somthing i would be doing with a street car cause theres lots that could go wrong and as
                deevergote stated (Camshaft adjustments should be made on a dyno.) i fully back what he says. i play with mine full well knowing that if i skrew up my cars dead for a while .. i got it for free so ohh well .. the risk is yours.
