help weird noise
    help weird noise
    ok so when i turn left or right doesnt matter, there is a sound coming from the driver side tire area it almost sounds like the wheel is lose.... it also happens somtimes when i accerate from a dead stop
    It could most likely be your axles, have you checked that?
    And if it is your axles get those replaced asap!
      a little more information would be nice. is that as good as you can describe it?
        how do you check if thier bad??.
        i just replaced the wheel bearings and that was a b$tch
          its like a clunking noise and feel.. i can feel it in the gas pedal and the steering wheel.
            sounds like your axle, are any of the boots leaking grease? did this happen after you replaced your wheel bearing?
              yeah a couple are cracked. i replaced the bearing about 2 months ago, this just started happening last monday
                if your cv boots are leaking grease the cv joint itself could be starting to seize because of lack of proper lubrication. make sure everything is tight in that area, look at all bushings and check the tie rods. from everything you have told me it sounds like the axle though
                  i think it is your axles mine are kinda doing the same thing i need to replace mine. and why we are at this were can you get a upgraded axle for a decent price.
                    http://www.driveshaftshop.com/main_cat1.php
                    thats all the upgraded axles i know of, unless your pushing crazy amounts of power idk why you would need them though
                      should i get new bootys and grease cv joint and see if that helps? or just a new axle?
                        if you have time, resources, and the experience to try regreasing your joints and installing new boots and doing it over again if that does not fix it then i would say go for it, mine were popping and i did that and it fixed the problem but i have access to a lift and have the proper tools to do it. but i would suggest replacing the whole axle due to regreasing is not going to fix it 99% of the time because your joints (depending on the duration of time without lubrication) have already been damaged
                          You need a new axle. That's what I'm understanding anyway. Sounds to me like a boot was torn or something and you leaked grease.
                          R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                            do you ever have any new information? it seems like your always just repeating what other people say
                              jus get a new axle that will b better
