my speedometer and odometer wont work help
    Just make sure if you seperate the electrical part from the mechanical part you dont loose the little pin inside.
    I once lost the little pin and thought my JY VSS was bad so I went and got another one, only to realize I lost a part I didn't know it had.
    Originally posted by chessboxer
    We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
    Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
      I replaced the electric part of my vss and my speedo still doesnt work. Does the mechanical part need to be replaced also?
        Originally posted by ghettoryde View Post
        I replaced the electric part of my vss and my speedo doesnt work. Does the mechanical part need to be replaced also?
        Did you lose the pin that goes in between them?
          No its in there. gauge cluster maybe?
            what about the wires?hv u checked them?happens to mine where 1 of the wire were pinched and shorted to gnd.seal it back & it works..
              i will check that. where was it pinched?
                ^^ once mine stop working i bought a nice one frm autozone nothing so i check mi wires for voltage and i didnt have a ground ran a ground fixed the problem.
                h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
                  got one want it
