automatic transmission problem....
    hey buddies i have a f22a1 honda accord 1992 and when I turn the car in the morning takes about 50 seconds to hook the reverse check the oil level and is in good.
    which will be the problem???
    I hope your help
    I hope your help
    you'll need a new tranny.. have you tried flushing the fluids?? then add slick 50 transmission treatment!
      Flush and pray. Also, it's slower when cold, especially in winter. Best to let the car warm up.
        Well, gotta a new trani :s
          i would put new fluid in it ..i only put honda trans fluid in it ..good luck 2.5 quarts..i let my cb warm up about 5min also
            Also check your transmission shift towers out. My auto was shifting slow, so I took them off and cleaned them with break cleaner. There will be two sets of two round cylinders towards the front of the trans. and wire running to them. There is three I think 10mm or 12mm bolts holding them on the tranny. unplug the wires. Take a wire from positive battery terminal to the plug. Then ground the body of the towers to the negitive terminal on battery. This will activate the tower plungers. Spray break cleaner inside the screen on the bottom of the towers. If you just unplug the wires from the towers and take a wire from positive battery terminal to the plug for the towers you will hear them activate. You will hear them click and sometimes the click is weak. That means they need to be cleaned. Alot of the time people say you need a new tranny. But there are a few things to check out before just spending big money on something that you can fix. Here is a site that explained alot on the hondas autotrany and some fixes you can do yourself. Techauto.awardspace.com/transmission.html hope this helps .
              AUTO/MANUAL SWAP IT!!!! lol.
              Accord SE
              93se
              Members Ride
              Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
              Sold to: sulimed, BurtonRiderT6, tishock
                incredible, the problem was in the pipeline transmission fluid, just change it and finally resolved
                  Aren't you glad you didn't need to replace the tranny like others said. Sometimes it can be a really simple fix for what seems like a complicated problem. Good job.
                    very nice
                    Originally posted by visualpoet
                    some owners think it's the best thing since titties
                      Cool man good to here you got it fixed yourself!
                        good to hear you got it going
