ok so as i have posted before i have a JDM F22B DOHC in my accord but have to rebuild it. it never ran right. what ECU do i need or do i need to chip it? can someone please explain.
Need ECU choice help!
Originally posted by ztaccord View Postok so as i have posted before i have a JDM F22B DOHC in my accord but have to rebuild it. it never ran right. what ECU do i need or do i need to chip it? can someone please explain.
Originally posted by DJ metadelic View PostKnock sensor in the block, and run a p14. That's what I've heard to do. Your running a p39 currently correct? DSM injectors with either an AFC hack or a standalone if you're gonna go fi...
Best bet is to find a p06 and find someone to chip it and burn a basemap on it for you, then go get it TUNED!3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
Originally posted by Father Time View PostRun a pt6 or use the p39 (as that was the ECU for THAT motor.)
The F22B DOHC does NOT have a knock sensor. I KNOW I swapped this into my CB.
DJ metadelic, please stop giving bad advice. If you don't know what you're talking about, don't regurgitated halfassed information that was told to you by other people.
ztaccord,
The P14 is NOT the best ECU to run. The P39 is the ECU you want. If "everything is stock", then I assume that you did not change the ECU, correct? Then you are probably running the PT3 or PT6, whichever came in your car initially. Get a PT3.
Honestly, if it's not running correctly, the ECU probably isn't your problem.
