my trunk caves in...water damaged or something...i want to know how to fix it...do i buy a new trunk mat piece? the one thats beige and is under the carpet?
how to fix a broken trunk mat
Plywood or MDF would be ideal. That cheapass cardboard isn't good for anything of weight on it.
Once I have the patience, I'll get a piece of plywood, cut out holes for my full size spare and battery, then wrap it with carpet.
home depot sells big sheets of clear plastic acrylic u can use that if u make a big template from cardboard that way weight is no issue. not sure about sag overtime but im sure it would hold up better than moisture getting to wood and rotting. wood is not meant for a car haha unless its properly sealed and treated.
Anyone else try this? kjnboi, how is it holding up so far?Originally posted by xkjnboix View Posthome depot sells big sheets of clear plastic acrylic u can use that if u make a big template from cardboard that way weight is no issue. not sure about sag overtime but im sure it would hold up better than moisture getting to wood and rotting. wood is not meant for a car haha unless its properly sealed and treated.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
I threw the old piece out months ago when it finally warped. I could use my carpet, but i dont remember the piece that big. Ill probably measure and use that or use a piece of cardboard and trace the carpet onto it and use that as a template for the new piece.
I think most of us have had to do something with the stock one because they tend to be broken or get broke.
