Cb7 wont start
    Cb7 wont start
    NO spark while starting, new plugs, rotor, cap n wires already been replaced. changed ignition coil n module. Still no spark at starting....
    please help me !!!!!!
    do u have power to the coil? is it the stock motor did u do a motor swap i need more info
    h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
      Yes, I did have power to the coil. stock motor 237k miles.
        does the CEL go off when you key the ignition up?
          no CEL at all. once in a while the car doesnt have spark n engine wont start due to lack of spark. I changed out coil n ignition modules, plugs, cap, rotor. Still no spark so, I'm norrowing it down to the CRANK/TDC AND CYL SENSORS.
            could be do u have an dizzy laying around the house or friend that has one u can borrow
              Check your ground. Is it grounding out where it should?
              R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                yeah i would check the grounds to deff the one on the thomerstat housing
                  have u tried to jump start the car maybe its the starter
                    Seriously?
                    He has narrowed it down to not having any spark, and this obviously has nothing to do with the starter. Also, if your starter was bad, you wouldn't jump start the car. That would mean the battery was not charging or dead.
                    Lets read the post fully before posting. Also, if you don't know what you are talking about, don't post. Answers should only be given by those with knowledge, posting BS answers does not help the OP out at all.
                    To the OP, check where the coil is grounding, then get back to me.
                      Originally posted by CB7 Sleeper View Post
                      Seriously?
                      last night i chk if the ignition switch was sending to power to the coiland it wasn't, So I took out the ignition and open it. I found the connector was bad rusted n corrosive. I clean them off and then the car started, once I turn it off it will never turn back on. So I bought a new ignition w/o the key. Now that the new ignition is install. I'm still havin the same problem...
                        Im guessing you should try this and see if you can figure anything out.
                        How to check your fuel relay.
                        1.Turn key 3 clicks, ( do not start ) now check engine light should eluminate on cluster.
                        2.Once it goes off listen to see if there is a click ones it stops eluminating. (Try this process a few times and if you dont hear a click. Relay's out.)
                        Hybridnation
                          Main relay is workin properly, I'm gettin fuel
