ok so i was just warming up my car then 3mins later i see the rpm starts jumping up and down and starts struggling between 1500-850 then 1500-400 then it just turned off, i tried to start it, the engine would turn over but and start but only for a second, my gas gauge is just right in the middle line of E, and my gas light havent turned on, i never drove my car on empty before but i know you still got another 20 or so miles before the gas light turns on, now my car is stuck over my friends house and idk what is causing it not to start, do i just need to put gas on it? and its parked on a down hill if that matters.
out of gas?
out of gas?
MEMBERS RIDE.
Bought from: DannyD
, Night Wolf
, CB7=91
, lummieCB7
Sold to: LITuner
, rezist09
, Pacman91EX
, 93AccordLXwhite
, PhatAccord
, TheNextEpisode
Tags: None
If its parked down hill, don't expect the car to turn on without gas due to the gas being foward instead of being leveled, Its common phychological sense, put a gallon or two so you can run to the gas station and pump more gas, don't crank your car without putting a bit of gas. You'll mess up your fuel pump and injectors...if you put gas and it dosen't turn on, then the fuel pump is dead my friend....Originally posted by CB7_213 View Postok so i was just warming up my car then 3mins later i see the rpm starts jumping up and down and starts struggling between 1500-850 then 1500-400 then it just turned off, i tried to start it, the engine would turn over but and start but only for a second, my gas gauge is just right in the middle line of E, and my gas light havent turned on, i never drove my car on empty before but i know you still got another 20 or so miles before the gas light turns on, now my car is stuck over my friends house and idk what is causing it not to start, do i just need to put gas on it? and its parked on a down hill if that matters.
oh ok thanks alot, i just wanted to confirm it.
MEMBERS RIDE.
Bought from: DannyD
, Night Wolf
, CB7=91
, lummieCB7
Sold to: LITuner
, rezist09
, Pacman91EX
, 93AccordLXwhite
, PhatAccord
, TheNextEpisode
No problem mangOriginally posted by CB7_213 View Postoh ok thanks alot, i just wanted to confirm it.
yea i think my car doesnt get 32mpg lol, but i get what ur saying.
MEMBERS RIDE.
Bought from: DannyD
, Night Wolf
, CB7=91
, lummieCB7
Sold to: LITuner
, rezist09
, Pacman91EX
, 93AccordLXwhite
, PhatAccord
, TheNextEpisode
thats sucks man, hopefully you don't have to replace the fuel pump, the cb holds about 17 gallons of fuel, whenever i get to empty and fill it up it stops at 13 gallons, that means you have about 4 gallons of gas left after your light turns on, and you should be getting fuel even if your downhill, if you were uphill maybe not. so it might be something else.
Release the e brake and roll that shit to the bottom of the hill...then try and start it lol.
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
lol thats what i did today hahahOriginally posted by Ander View PostRelease the e brake and roll that shit to the bottom of the hill...then try and start it lol.
MEMBERS RIDE.
Bought from: DannyD
, Night Wolf
, CB7=91
, lummieCB7
Sold to: LITuner
, rezist09
, Pacman91EX
, 93AccordLXwhite
, PhatAccord
, TheNextEpisode
OK here are a few things to check:
1. Put more gas in the car, see if it will start.
2. Can you hear the pump when the you turn the key?
3. Check if the ECU is not loosing it's ground? (the bottom bolt on the thermostat housing)
4. Check the main relay. (Under the driver side dashboard)
one time mine ran out of gas, i had to put 3 gallons in it make it start again!
Good advice, I was gonna say get some starting fluid and spray a ton of that shit in there, it would run the car for a second till you got it off the hill. lolOriginally posted by pedroalcala View PostIf its parked down hill, don't expect the car to turn on without gas due to the gas being foward instead of being leveled, Its common phychological sense, put a gallon or two so you can run to the gas station and pump more gas, don't crank your car without putting a bit of gas. You'll mess up your fuel pump and injectors...if you put gas and it dosen't turn on, then the fuel pump is dead my friend....
