i have a 93 cb7 sedan dx f22a6 ... the motor blew so i replaced it with one out of a 91 cb7 sedan ex f22a4 does the ecu make a difference or nah
ecu question
not really, a6 ecu is more agressively tuned thans the a4, but you won't have any problemsOriginally posted by h22accordlxvtec View Posti have a 93 cb7 sedan dx f22a6 ... the motor blew so i replaced it with one out of a 91 cb7 sedan ex f22a4 does the ecu make a difference or nah
there you go...i agree.Originally posted by CB7 Sleeper View PostYou should probably get an H23 intake manifold with the IABs, and an A6 cam. The ECU for the F22a6 is designed to run these components, and more aggressively tuned. If you still have your engine you should be able to salvage the intake manifold, and the cam. Then it will basically make it an F22a6.
The DX should have had an F22A1, not an F22A6. The ECU in that car should be a PT3, which is the same ECU that runs the F22A4. If for some reason it WAS swapped to an F22A6, and the ECU matched (PT6) then it won't hurt anything.
Coupe, sedan, or wagon... makes no difference.
This thread is not about what he should do to his engine. Please don't randomly suggest performance upgrades... That will only cause confusion.
Makes sense, sorry deev. Just felt the need to make a suggestion assuming he had the old F22a6 (if that's what it is) around.Originally posted by deevergote View PostThe DX should have had an F22A1, not an F22A6. The ECU in that car should be a PT3, which is the same ECU that runs the F22A4. If for some reason it WAS swapped to an F22A6, and the ECU matched (PT6) then it won't hurt anything.
