Calipers/Big Brake upgrade question?
    I was clean my car today. And was scrubbing the rims when the question can to me. What will I do after I convert from 4 Lugs to 5 Lugs. What Calipers or Big Brake kits are out there for are cb7's after a 5 Lug conversion? What will I need to get to get the setup to work? So can anyone help me and point me in the right direction. Thanks in Advance.
    u dont need bigger brakes than oddysey or prelude vtec
    as for rotors
    get slotted for prelude or oddysey
    Just do what PR CB7 said.
      as for rotors
      Do you mean to use the Prelude/Odyssey Calipers? And I know I really don't need the added stopping power. But it could come in handy plus the look of having a big brake kit looks awesome.
        once your 5lug
        look up big brake kit for prelude
          when u do the 5 lug w/e cars knuckles you use u use their big break kit its not complicated if u sit down and think about it.
          [COLOR="Magenta"]
            what makes people think they need a big brake kit anyways?? just because you get bigger rotors or calipers, doesnt mean its better than the stock system (or you will stop 10x better). People overlook the most important factor. The damn brake pads....
            F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
            Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
            Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
              or the most important thing, tires.
                PowerSlot makes a prelude big brake kit
                http://www.racinglab.com/powerslot-plus-29519.html
                and the rear big brake kit you would get for 98-02 accord v6
                http://www.racinglab.com/powerslot-plus-29623.html
                Wilwood makes a complete big brake conversion kit with calipers
                http://www.wilwood.com/BrakeKitList....&model=Integra
                with the powerslot kit you keep your stock calipers. i am going to purchasing the powerslot kit and using 07-08TL typeS calipers.
                MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
                CHAMPCOUPE IS BACK !!!!
                  in daily driving situations you are 100% correct. but on the track and autocrossing it makes a big difference. it depends on what he will be doing with the car.
                  tires dont mean shit if you cant stop the car. brake pads will do more than tires.
                    i posted some links s you can check out the bb kits. if you are just dd the car. get some good brake pads and ss brake lines. drain your old brake fluid and replace it with new brake fluid and you will be good.
                      90-93 acura legend calipers the dual piston ones!!!! you can get them cheap too!!
                        Really?
                        What bracket do u need to use to put those on?
                          23 T / accord wagon 94-97......vtec prelude has to be H22... or acuraTYPE R
                          the way you put them on correctly is swap sides so bleeder is upside down.lft goes on right.right goes on lft kinda *** but have to install like that to be correct
                            I didn't know we are able to use 2000 Acura Integra Brake Kits. Is this true?
