No start?
    No start?
    Ok well i thought my fuel pump was bad but even with the new fuel pump i have an intermittent no start issue... when the car doesnt start i do not hear the pump run...
    So im thing main relay or ignition switch??
    any help?
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    main rely mi cuz use to be able to make his start by hitting the dash board under the steering wheel or the main rely it self
    h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
      My pump will turn on if i turn the key on/off repeatedly once i hear the pump it runs just fine
      It only happens once in a blue moon
        OK well any help? how hard is it to replace the ignition guy?
          Not hard to replace the ignition, my brother in-law did it, and he's not mechanicly inclined at all. But If its just your fuel pump that doesnt turn on, then i dont think it'd be your ignition. could very well be a relay.
          Depending on what actual relay it is, I might have one, i always leave the j/u with a bunch of little shit like that. I'll figure out which one it is and let you know if I have it.
            Ok well id be game to try that first but i know my ignition is messed up aswell because when you open the door and take the keys out the car still beeps at you until you close the door
              Think thats normal, my car does that too.
                mine does not beep unless the key is in or the lights are on i think it`s the key switch
                  I swear I remember mine doing it, but I just went out and played with it, doesnt do it. My bad.
                  But I still thinking that if its only the the fuel pump that doesnt come on how can it be the ignition switch? Ignition switch doesnt control the fuel pump on a separate circut then then rest of the electronics does it?
                    you can check for power too the pump by the plug behind the back seat it`s the yellow wire it goes in at the sender cover
                      well i have a spare main relay that i know is good so i will throw that in there as well... The problem is that it just happens when it wants to...
                      The ignition i think ill have to replace just as an annoyance factor( 230 bucks sucks though)
