Hi guys. My apologies if this has been covered over and over again. I have been scouring the forums for insight into my problem with some luck, but still not 100% sure.
Anyways, I bought my 1991 SE a couple weeks ago. I knew from the beginning that it had an ignition problem, as the previous owner said that while driving it, it had just randomly stalled while driving along, or sometimes would hesitate while cruising at constant speed, or also hesitate under acceleration. Occasionally the CEL would be triggered, but not all the time.
I began driving the car and didn't have any stalling issues, but I would occasionally get the hesitation, atleast once every time I drove the car.
I have had 2 instances where the car did not want to start (one was a cold day, about -20c, the other was today, about +4c). After a few tries, it would fire up like nothing was wrong.
Today, I replaced my thermostat (unrelated to my ignition problem obviously), but to help get access to the tstat, I removed the distributor cap. I got my work done and put everything back together, started the car and went to go for a drive to see if the new tstat was working. I got as far as the end of my street when it just stalled in the middle of the road doing about 30kmh. I have had it stall on me around 40 and 60kmh as well.
SInce that happened, I have only been able to start the car 3 times, and even then it does not stay running for longer than about 1 minute before it will stall. It cranks over just fine, but obviously has no spark. When I crank it over, the tach needle doesn't even move. I should also mention that while driving, my tach needle would sometimes be all over the place,fluctuating within 2000rpm of the actual engine speed, so I am assuming this is distributor/ignition system related.
So I've broken it down to either I need a new distributor assembly, Ignitor or coil and/or cap & rotor. My dizzy has absolutely no free play in it whatsoever.
I also lost the spring that sticks into the coil inside the distributor cap.
I'm at the point where my car cranks fine, my fuel pump works, the car runs fine when it does start, I'm just not getting any spark. Before I go and spend tons of money on new parts, has anyone had the same or similar symptoms?
From what I've read on here,ignition problems are pretty common on the F22A's.
Thanks for your help. This forum has been a great wealth of knowledge so far!
Mike
Mike
PSN: REDxMAN-_-
