you havent specificed a code yet.
Ignition issues
I don't understand why everything went to shit just from taking my cap off originally so I could get to my thermostat. It always started and ran fine, other than the occasional hesitations. Now it just doesn't start at all. It it does start, it will idle smoothly, but die as soon as I touch the gas.
i just recently bought my cb, and it was doing the same thing... the Previous owner had replaced the distributor assembly about a year ago... i went ahead and got another one under warranty, and i havent had a problem since... been about 750 miles so far... if i were you, i'd get the whole distributor, the ignitors like to be finicky on these engines, and w/ a new dizzy, you'll get that and a coil and the cam/crank sensors too. you're tach issue will be distributor related as well...
91 EX Coupe 5 Speed
My Ride Thread
ASE Certified Master Tech Since 2005
Bought From: QuakerjoeOriginally posted by deevergoteThat's like watching a guy stick his head up his own ass. Impressive... but why?
, MikeW
Okay. Today I installed a new coil and new plug wires, along with a new cap and rotor. Car cranks and cranks and cranks. Started once and idled until I touched the gas and it died.
I have no clue what ground you're talking about on the tstat housing cuz I don't see any wires or anything that could be a ground other than the green plug that plugs into the side of it.
When you turn the key on, are you supposed to hear the fuel pump kick on? Mine doesn't make any noise. That is my next plan of attack. Next question, is a fuel pump from a 93 EXR compatible with a 91 SE? I can get one for free tomorrow if this is the case.
And if I need an ignitor, it's $154 from the Honda dealer and it won't be in til Wednesday if I order it.
PSN: REDxMAN-_-
