Hi guys, I know this should be posted in the technical forum threads, but since I'm a new member I can't do it yet. I'm going to swap an F22b dohc that I recently purchased into my 1990 accord this summer. What I was wondering is the P14 ecu from a H23 a suitable substitute for the P39 ecu which comes with F22b dohc? I know this can be done due to research I've done on this site, but how well will this combo run the motor? Will I get the same performance or close to same performance as I would with P39 ecu? Thanks for your input.
Will F22B dohc run right on a H23 Ecu?
Originally posted by HondaMechanic View PostHi guys, I know this should be posted in the technical forum threads, but since I'm a new member I can't do it yet. I'm going to swap an F22b dohc that I recently purchased into my 1990 accord this summer. What I was wondering is the P14 ecu from a H23 a suitable substitute for the P39 ecu which comes with F22b dohc? I know this can be done due to research I've done on this site, but how well will this combo run the motor? Will I get the same performance or close to same performance as I would with P39 ecu? Thanks for your input.
The P14 won't be right, obviously. It'll run, and probably do so without doing any damage, but it's not right.
Most people I know just use the PT3 or PT6 from their F22A.
yes but diffrent spec's one is JDM other USDM
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
Originally posted by HondaMechanic View PostBut aren't the H23 and the f22b dohc very similar engines?
It's probably closer to the F22A than it is the H23A1. Spec-wise, it kinda falls right in the middle.
No ECU from any other engine is going to run it 100% correctly, though the PT3/6 or P14 will do the job well enough.
JDM F22B DOHC ecu is the p39. Heard they were hard to find though.
H23 also has a knock sensor that the F22B DOHC does not have as well. So you would have to wire one up IF you chose to do that.
I used my pt3 for a while when I did this swap and though it wasn't putting putting out the full potential of the motor, I did not have an issue with driving or idle. The only issue I had was the pt3 ecu doesn't support the IAB's and also caused the motor to run a little on the rich side.
Others have had better luck with the pt6 ecu as it has the capability to control the IAB on it.
Bottom line: I would use the pt6 rather than the p14 or pt3 till you were able to get your hands on a p06 ecu and get it chipped and tuned. NOT JUST A BASEMAP! TUNED like dyno tuned or the tuner sits in your car and tunes you while you drive.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
Originally posted by HondaMechanic View PostCouldn't you just run the F22b dohc without a knock sensor because it doesn't come with one originally, if you used the P14 ecu?3 CB's gone....
1 WK Overland....
That would make sense that it would throw a code. What is a llama? Is it some sort of piggyback system or coversion harness?Last edited by HondaMechanic; 01-15-2010, 12:47 PM.
Originally posted by chessboxer View PostCan I just wire one up on my llama though? I got a really good deal for one with no rust on craigslist.
Originally posted by NWaccord View PostYou Probably better with a chipped ecu with a basemap, eliminating knock and egr sensor! Then tune in the future.
