speedo !!!!!
    speedo !!!!!
    ok so here we go i just put my h22 in and the speedo not working rpm is but not the speedo , so im a tech for litha toyota so i pull up the wiring diagram ON ALLDATA WHICH IS LIKE A BIBLE TO US, the wiring on my car is not the same as the diagram? they say theres are a orn- which is suppost to be vehical speed output/ then yel-12volt/ blk ground? my harness which is f22 harness is yel with white/ grn with white/wht with black? WTF so i call honda and talk to a tech he said come on down and look at the wiring book for that car so i did still the same as on alldata and chilton and every ether book know to man! so my Q is why r they diff. than my car, i even took the dash out and check harness behide the speedo which should be ORN? nope blue with red strip!!!! im pisssed i know which on is my 5 volt to ecu check with voltmeter but no 12 volt or ground so i made my own 12 volt/ and ground still nothing? i just order up the sensor be here in like 4 days ? when i check the old sensor it did not pluse . thats why im odering a new one ? MY BIG Q IS WHY R MY COLORS DIFF FROM ALL THE BOOKS AND ALLDATA???????
    Please use correct punctuation when possible, more people will be inclined to help. That was hard to read to be honest.
    I am not sure why, but they could just have used a generic obd-I diagram, perhaps the wires in question lineup to a civic, as I have seen that happen on sensor wires and other things.
    Apart from that guess, I do not know.
      no even the dealer wiring diagram are the same says the same thing as alldata and all the repair books
        talking about the speed senors if anyone else is wondering? wiring for it
          found out that someone replaced it with a civic harness thats why thanks
            Hey, I know a guy who said that might have happened!
            Glad to see you got it figured you.
