replacing axles backwards ???
    i have to replace my passenger side axle , its messed up bad . im removing the transmission so the side that goes into the tranny is out , how do i remove the side connected to the hub ? if i turn the 38mm it would just turn the axle.
    ive researched around here and all the pages say remove the 38mm first and then pop it out the tranny ..
    any ideas?
    alone in this game . ::My Ride My Way::
    any ideas?
    put the other end back in the transmission, then remove the hub end first. After you remove the large nut, tap the axle out of the hub with a brass or wood mallet(so you don't dent the axle). Then remove the end that's in the tranny.
      this.
      its not gonna come off unless you have a drill that will turn while some strong man that benches 400lbs s a warm up exercise hold the axle so it doesnt turn.
