I have a 93 Honda Accord SE (auto)with 217K. Here's what I been replaced and checked. Fuel filter, spark plugs, spark plugs wire, fuel injectors, fuel injector resistors, cap and rotor for the dizzy. Clean out the throttle body, Did check timing. And its looks good. Changed 02 Sensor too. It's OEM Denso. Cost me almot 95 buck from the local Honda stealership. Gas mileage is terrible, and it's kept bogging down. First it's show code 43 for a while even I changed swap with the new 02. Now it's won't show any code, but it still bogging down. One more thing my fuel gauge on dash did not work at all. I have to use the trip odometer and when it's around 200-250. I have to stop and fill up my gas tank. The gauge is only shows it's full mark. I did take out the fuel sending unit, take a look, and put it back. Did not have time to test it yet. Think about getting it from the junkyard this weekend. Any body have the problem like this before? I tried almost everything, seaform and such. Car is start and idling fine, just bogging down randomly when I drive. Any else do I need to check?
car still bogging down ( real bad)
Bump. Anyone? I did also clean out the IACV, did check the main relay, air filter is still good. Did check the fuel pressure, and I can hear the fuel pump prime when I put the key in the ignition. Also I did check the spark, by pulling the sparkplug wires once at a time. I run out the idea now. Can some one help me out? Thank you.
You mean the main relay? I did swap with the good working one, but it's still bogging down. I don't think the main relay, though cause the car is still start even the weather is hot, or cold. It's just bogging down randomly when I start driving it. Anyone else?Originally posted by cb7 dohc View Postdid u check the relays uder the dash or change the ecu out it might help
Honestly, if that's a consideration then I would drop it out and give it a looksie. Although it could be a vac leak because this happened on one of my EG's, and you said you changed the plugs, so I think them being fouled is probably not likely.Originally posted by 93SE View PostTiming belt was changed a year ago. I wonder the same thing a about the cat, too since it's a aftermarket cat. But it did pass AZ emission test 2 year ago, though.
life is good.
When are you going down to the Valley? I heard on TV it had a nasty storm last night up there. I was thinking swap the cat with the CRX cat I used to have, but when I went to the muffer shops they said they can not do it like that because the EPA bullcraps. I need to go some where and get a hold of the welder and start rig the old one out, and put my stock Honda CRX back inOriginally posted by Teddy View Postvacuum leak,compression test? i got the gauge i could bring it down to you
I just take a look at the receipt. It's almost 140 with taxOriginally posted by jimwards17O2 sensor for 95 bucks? Nice. They're way more than that at my local "stealership". I would check your fuel pressure and see if that's normal, then go from there.
. I also did check the fuel pressure, and changed the fuel pressure regulator. And its's still good.
sounds like a lack of fuel to me... perhaps MAP sensor?91 EX Coupe 5 Speed
My Ride Thread
ASE Certified Master Tech Since 2005
Bought From: QuakerjoeOriginally posted by deevergoteThat's like watching a guy stick his head up his own ass. Impressive... but why?
, MikeW
